I am stumpped and I really could use some good advice. I have a 9N with a front mount distributor and a 12 volt conversion. I am not getting any spark at the plugs. I am getting 3 to 4 volts at the coil with the resistor in line and 12 volts without the resistor in line. I have changed the coil, plugs, points, rotor, distributor cap and condensor. I believe something in the distributor may not be working properly but I don't know how to determine what it is.1) I removed the breaker plate, cam and weight assembly. Is there a specific way to reinstall it? To me, it appears that it just drops back in. Am I correct? 2) When I reinstall the distributor on the engine, I just line up the tang on the distributor with the slot on the engine thigamajig (crankshaft?)and the distributor installs flush with the engine block. I line it up by rotating the rotor. Is this correct? 3) While having this problem my starter drive busted-up and I replaced the starter drive but I don't belive that this has anyting to do with the problem. Do you agree? It wouldn't start before I replaced the starter drive and it hasn't started since I replaced the starter drive. 4) This problem started right after I pressure washed the tractor. I think that this is a coincidence. Do you agree? 5) I don''t understand how to check the voltage with the points open and the points closed. How do you know when they are open and how do you know when they are closed? Do you check it at the coil or do you check it a a spark plug wire connection at the distributor cover plate? I have a volt meter. Any advice that you can give me would be greatly appreciated. Thanks.
