As Phil indicated, you either need to fabricate a stabilizer that keeps your 3pt drawbar from rotating, OR buy a 3pt hitch receiver made specifically for a trailer ball, OR finish assembling your towbar. You'll find that you nned a bar that goes up into that narrow area under the diffy. then you can slide a pin up thru and use a hairpin to secure it.. pin only needs to be 2" long or so... I ended up using a cat 2 toplink pin I think.. and cutting it down. The towbar than sets atop your 3pt drawbar, and uses various stailizer methods.. I've seen many different setups. Phil has a couple good shots. A suitable tow bar is available at tractor supply. On mine I then used a 'U' bolt to limit the towbars movement on the 3pt drawbar.... works well enough Alternately, you can weld a cheapy one up like I did for my NAA... the ugly bracket I made is merely a piece of rebar bent 90', and has two pieces of 2" ibeam welded to it. The ibeam on the 'top' saddles one of the lower lift arms, and attatches with a u-bolt. the other ibeam saddles the 3pt drawbar, and has a bolt welded to the bottom of it that aligns in one of the drawbars holes. then add a washer and locknut, etc.. and it is mounted... the drawbar cannot rotate in relation to thelower lift arm... keep in mind.. if you lift the lower lift arms.. you will change the angle of the drawbar.. so i always ran mine with the lift in the down position.. worked greak on a hay ride... This one is quick and dirty.. and was made from 100% free scrap iron I 'liberated' from my day jobs scrap heap... The only thing uglier than the design.. is my welding skills.. or lack therof. Soundguy
