Ok,Either my tractor is possessed by one of the old horse farmers that likes to play games or I need some more advise. This weekend I changed out the exhaust/intake manifold and muffler (at Dell's recommendation) thinking there might be a crack between the exhaust and intake chambers, but that was not the case and I still have a sputtering/backfire problem, seems worse now the a few weeks ago. The problem is now happening as soon as I start the tractor. Here is the kicker, she will run terribly for 15 or so minutes and then all of a sudden, woola, she is running like a champ, no sputtering or backfire and plenty of power. She will run like this for 10-15 minutes and as quickly as it came on, it is over and she is running terribly again. So yesterday, I checked the plugs which are only 2 monthes old and they were dark black with a lot of soot on them. In fact one of them wouldn't even arc. So I ran up to the parts store and bought and gapped four new plugs thinking my problem was solved, but not... she still sputters and backfire something aweful. I also checked the distributer, looked fine. Looked at and reset the points, they all looked good. Bypassed the resistor, and rewired the coil, all of this did not fix the problem. Again, the following has been replaced in the last couple of monthes. Coil Ignition Spark plug wires spark plugs distributer cap points rotor condensor manifold resistor voltage regulator (cut out) carburator new gas w/dry gas additive Please help, I am going crazy trying to figure out this problem. Why would the tractor run fine all of a sudden and then go back to sputtering after 15-20inutes of good running. thanks rob
