Sputtering Cont....
Rob in VA
02-03-2004 13:22:58
By the way, I forgot to mention that the other day after we replaced the sooted up spark plugs, the old girl was still sputterin like crazy, then we took off a sprak plug wire, no change. We then took off another spark plug wire and it worsened the sputterin by just a bit....runnin on two cylinders. I guess the question is do most of you still think it is a carb problem. Or do I go ahead and order new electical components ie. condensor, points, rotor and cap...
The possessed tractor owner
Steve W (NY)
02-03-2004 14:06:34
 Re: Sputtering Cont.... in reply to Rob in VA, 02-03-2004 13:22:58
Just for Giggles....swap those two plug wires and report back. I consider myself farly competent, and yet I messed up the firing order on an old Massey once. Amazing how well they run on two cylinders with the other two crossed.
Take Care
Steve
jeff
02-03-2004 14:17:13
 Re: Re: Sputtering Cont.... in reply to Steve W (NY), 02-03-2004 14:06:34
Rob, is it possible if the distributor was pulled that you may be 180 degrees off when it was put back in?
