ORC, New PTO, Naa Piston,
B. Jones
02-04-2004 10:52:37
I got out the old calculator this morning and found out that this Site has gotten expensive for me. I found this site just about 3 months ago and low and behold found out about the Zane Thang, got one. Then I ordered a new voltage regulator, got that. After reading Dell's post I decided to order the ORC along with the new PTO shaft, update to 1 3/8. I've mowed without one for years but decided that he is correct. I've also put on the new style starter drive and just yesterday ordered the NAA piston to upgrade the hydraulics. When spring hits I may look into the governor, it works ok for now. I have learned so much about the old 2-n that I never knew about before. All the snow seems to miss us here in North Missouri, so I did not get to try out the rear snow blade. Please don't tell me about something else that my tractor "NEEDS".
Bruce (VA)
02-04-2004 11:25:27
 Re: ORC, New PTO, Naa Piston, in reply to B. Jones, 02-04-2004 10:52:37
Your tractor needs operator maintance.....add 12 ozs of beer every 2 or 3 hours of operation. Increase to 2 or 3 beers when the tractor is turned off for the day.
Jeb2N
02-04-2004 13:38:30
 Re: Re: ORC, New PTO, Naa Piston, in reply to Bruce (VA), 02-04-2004 11:25:27
Your tractor NEEDS love and attention. Spend as much time with it each day as is practicable. Don't forget regular maintanance/care/feeding of the tractor like oil changes, rear end fluid changes, coolant check, and the occaisional tune up. Every now and then, give it a lollipop for being good. That or a good washing. Speak kind words after good performance and when trying to crank in cold weather. Also, showing off on 4th of july is appreciated (tractors love attention).
Jeb-self appointed tractor abuse counselor
