Still Sputterin (part......i cant remember)
Rob in VA
02-07-2004 05:05:48
First off, I want to thank all you for your great support and advise on my mysterious sputtering problems on my 9N. I also want to apologize for not keeping you all up to date on the progress. Its not an excuse, but I just recieved my logs for my log home and have not had a chance to do any trouble shooting or posting. But on Wed, I did have a chance to spray gas in the carb as she was sputtering (no change) I then hooked up a funnel contraption to the gas fitting on the carb and poured new gas into the carb, again (no change). It was kind of funny because after I checked those two things, I was sittin there cussin the old girl, and all of a sudden she ran like a top. Well for a few minutes anyway... I think she was laughing at me... I just received my new electronic parts that I am going to replace, ie condenser, points, rotor button, cap and resistor. (Lots of spare parts if this does not work). If all of this does not work, then I will take a lot of your suggestions and check for a sticking valve. Again, sorry for not keeping you all posted about my progress, I will try and do better. Thanks for all the great advise.
rob
Danny in CO
02-09-2004 07:36:36
 Re: Still Sputterin (part......i cant remember) in reply to Rob in VA, 02-07-2004 05:05:48
Rob,
I don't remember all that you have done. Have you checked the valves? Could you have a couple of valves that are sticking sometimes?
Good luck,
Danny
John IA
02-07-2004 12:20:32
Rob,seems to me I was reading on the Ford Board of a guy haveing a simular problem. It was either a cracked intake or a bad intake gasket. So look these 2 over good on your way to checking the valves. I thought for sure it would have been one of the filter screens. Good Luck John
Rob in VA
02-08-2004 05:31:31
 Re: Re: Still Sputterin (part......i cant remember in reply to John IA, 02-07-2004 12:20:32
John,
I am pretty sure it is not the intake because I just replaced the manifold and the gasket last weekend. Will let you know how the valves look.
thanks
JohN 50
02-07-2004 11:25:24
Me thinks and I try not to do that to often, you need to remove your dist. and give it a complete overhaul. I had the same type of problem on mine. If you could have seen the shape that dist. was in you would wonder how the tractor ran at all.
old
02-07-2004 08:35:37
If them parts don't fix it its the switch or the wires going from the switch to the coil. I still think you have a PHATOM short in the system
