Order Ford 9N Parts Online
9n battery /fuel door
Rob Morris
03-05-2004 19:52:58
I have a 1939 9N (serial #1741)and am looking for a supplier for the battery/fuel door and battery splash cover. The battery door doesn't have the hinges like the later models. Dennis Carpenter doesn't carry these items. Also would like to find some original style running boards. Any information would be appreciated. Thanks,
Rob
Scott
03-06-2004 16:42:53
 Re: 9n battery /fuel door in reply to Rob Morris, 03-05-2004 19:52:58
In 2001 a fellow in WI advertised steel ones for $100.00 ea. w/ shipping his number was 608-326-8017 after 6:00pm, I do not know if he is still selling them.
Dell (WA)
03-05-2004 23:27:04
Rob..... ..the original early 9N fuel door was "friction-spring" attached. I don't know how close in dimensions it is to the later hinged mounted door. (which you'll have a whole lot better luck finding) Personally, I like the hinge-mounted door. ...BUT... if'n ya gotts yer little ol'heart set on having a fuel door just like the "original", HIRE IT DONE.
Hot-Rod body shops are always making panels by "hand" for their old Ford roadsters. Patching rusted out body parts, etc. Just tell the body guy you've got an old Ford convertable. Bring in a cardboard template to start with. Should be simple to do as there ain't no compound curves, just a simple center crease and folded edge lip. And bring $$$$..... .respectfully, Dell
9n141
03-06-2004 08:40:33
 Re: Re: 9n battery /fuel door in reply to Dell (WA), 03-05-2004 23:27:04
Early hoods were aprox, 1/2 in. diff in width at the raised part at the hinges. We find the hinged door is too wide and if you use proper 4 spoke steering wheel the hinged door will not open past the steering wheel. BURT.
souNdguy
03-05-2004 21:34:54
9n and 2n tractors had foot pegs only.. there are no 'original style' running boards.. as the 8n was the first N with running boards. That said.. lotsa farmers either fashioned their own, or found some to buy. Popular design is a board that hangs on the foot peg, and is attatched to the round dipstick covers by an L-shaped bracket.. etc.
I havn't seen them here.. however I have seen them in the classifieds of the n-newsletter mag.
Soundguy
