Generator length
Rob N VA
03-26-2004 12:32:28
I remember I read a post a day or so ago about the length of a generator in question. If I recall correctly, the genny was too close to the oil filter?
Anywho, I took a look at mine today and noticed that mine was the same way, only someone had welded a small tab on to the bracket to move it over an inch or two, and only used one bolt. Hope that sheds some light on the subject!!---Rob
Willy-N Picture
03-26-2004 18:52:42
 Re: Generator length in reply to Rob N VA, 03-26-2004 12:32:28
third party image
I looked at your generator and it is mounted wrong? Here is a 8N generator & bracket that fits your engine. Mark H
TJ in MO
03-26-2004 17:48:45
I'm not sure if this helps or not but I found this pic on ebay. The ad claims original generator and bracket.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3806448888&category=56178
Bob
03-26-2004 16:47:17
I went out and checked out the filter situation on my 1951 side-mount 8N that needs restoring. Generator is missing, so I don't know what length it was.
The cylinder head does not have 4 oil filter mounting holes, as someone suggested in a previous post. However, there is a large, rectangular, flat raised area or "boss" where the front oil filter bolt hole is, and the hole is drilled way to the back of the raised area.
The centerline of the front oil filter bolt hole is 5-5/8" rearward from the machined surface at the front of the block, where the waterpump mounts. Does anyone have that dimension for a front-mount series?
Tom
03-26-2004 13:53:33
Hey Rob, Yeah, That was me that posted that question. Mine is secured with one bolt as well. It seems to work fine (for now) but it's just a bit annoying. I'll be rebuilding my 51 later this year so I have that on the list for something to fix.
Regards,
Tom
