Where is it?
Rob N VA
04-06-2004 18:49:36
Where is the oil hole on the generator? The hole on the distributor is pretty obvious, but I can't find the one on the genny. Do all gennys have an oil hole, and therefore possible mine dosen't have one. Thanks!!----Rob
Willy-N
04-06-2004 18:55:27
 Re: Where is it? in reply to Rob N VA, 04-06-2004 18:49:36
The 4 generators I have pictures of it is on the rear bearing side either a tube and cap or just a cap. They are 9N, 2N & 8N generators. Mark H.
Rob N VA
04-06-2004 19:01:30
 Re: Re: Where is it? in reply to Willy-N, 04-06-2004 18:55:27
OH, sorry!!!
This is a 1950 8N, with a sidemount distributor. As far as 3 brush, or 2 brush, I have no idea. I looked for it but I couldn't find the litle hatch "thingey". I am assuming the hatch is long since gone, but the hole remains. Just can't figger out where the oil access should be. Anyone got a picture?
Willy-N Picture
04-06-2004 20:39:44
 Re: Re: Re: Where is it? in reply to Rob N VA, 04-06-2004 19:01:30
third party image
Here you go. Sure glad I saved these! Mark H.
Sealed bearing..John,PA
04-06-2004 19:04:22
The bearing on the pulley side is a sealedtype bearing. There is an oil port on the rear nfor the bronze-type bearing. Probably the spring cap is missing.
