Weak Hydraulics (Zane) or anyone
Avery
04-26-2004 11:55:23
What I've done so far.
Reworked top cover.
Drained and cleaned pump cavity.
New oil.
I know I need to put naa o ring seals in
ram. I have leak down pretty quick. Steady stream of about the size of pencil lead
not pencil.
It lifts fine with about 200lbs but if I put my 200lb body on lift it will not lift.
Finger on the end of safety valve and can not feel
oil pushing on it. I have changed the safety valve
with one that was apparently good.
I have read Zane's post about trouble shooting but
cannot find anything apparent. What do you all think, will the naa seals fix my
problem or will I have to go deeper.
Thanks for any help
Avery
Dell (WA)
04-26-2004 18:03:06
 Re: Weak Hydraulics (Zane) or anyone in reply to Avery, 04-26-2004 11:55:23
Avery..... ....iff'n yer seein' yer current lift piston pee, then its NO ARGUEMENT, you need to change to new NAA piston and "O-rings". O-rings won't fit the 3-ring N-piston..... ...Dell
Avery
04-26-2004 18:45:19
 Re: Re: Weak Hydraulics (Zane) or anyone in reply to Dell (WA), 04-26-2004 18:03:06
Hey thanks Dell (but) Do you think thats all I need. If the pump needs
a kit or cleaning I would like to do it while
I am at it.
Later
Avery
