Need to seal the hydraulic oil tube.
Rob
05-09-2004 17:19:10
My 8N has modified hydraulics. The oil tube from the pump up the side of the center housing has been cut and a control installed. The oil tube is a slip-fit into the bottom of the control and slip-fit out the top. Might have been more of a press-fit once.
Problem is the slip-fit into and out of the control leaks some. I loose hydraulic pressure out those leaky slip-fits. My lift isn't a strong as it should be. Is there some goop I should use to seal that tube/control joint? Can I smear some silicone on that tube before I stick it in there or what? I'm thinking silicone might be alright in that oil, temp, and pressure.
Never had a pump off. How does that tube seal into the pump base? Slip-fit?
