BAD SIGNS?
BOB G (TEXAS)
05-16-2004 19:00:31
I have a 9N with a 12 volt conversion.
1. There is a 3/8" diameter hole in the engine block (housing) about one inch back from where the starter bolts to the housing. When the engine is running and the transmissin is in neutral I can see a lot of sparks inside of this housing. It looks like a fireworks display. Is this unusual? Is it a sign of a possible problem? What is the purpose of the hole? I recently replaced the starter drive.
2. I changed my hydraulic fluid for the first time. The stuff that I drained out was the color of muddy water. Is this typical?
Any advice or comments would be greatly appreciated. Thanks.
Dell (WA)
05-16-2004 22:10:12
 Re: BAD SIGNS? in reply to BOB G (TEXAS), 05-16-2004 19:00:31
Bob..... ....kinda hard to guess about your hole. It shouldn't be there. Does it look like its been drilled? Could have been drilled to un-stick a starter bendix.
And NO, you shouldn't have sparks grinding away inside yer tranny housing. Theres something drastically WRONG with your starter bendix and iff'n ya don't find out why, yer gonna be buying a NEW STARTER MOTOR ($150)
And NO, your tranny oil should be a clear light brown fluid. Chockalate milk lookin' fluid is caused by WATER. Check yer tranny shifter rubber boot ($3 cheap)..... ....respectfully, Dell
Fast Ed Ohio
05-16-2004 23:26:53
 Re: Re: BAD SIGNS? in reply to Dell (WA), 05-16-2004 22:10:12
Hmm, Kinda sounds like the starter bendix aint going back into place and is hitting the teeth on the flywheel, just my guess, dont think I would use it much untill the problem is corrected.
Jeff TX
05-16-2004 19:21:10
I would guess your starter bendix is either staying engaged to the flywheel or it is flopping around and striking the flywheel. Better check this before it eats up the flywheel starter ring. I may be wrong this was just my guess.
