Order Ford 8N Parts Online
8N bogging under load?
Rob
06-12-2004 13:23:47
I have a 1950 8n with a front mount dist. When it is under a heavy load such as starting out in fourth gear or when starting out with the brush hog on it will bog way down almost to the point of stalling then it will pick back up then and run fine. The engine recently had the rings replaced and the valves grinded, the carb was rebuilt and new points, condensor, new coil, new plugs and wires. Any ideas what could be causing it do this? Thanks Rob
Dell (WA)
06-12-2004 14:56:40
 Re: 8N bogging under load? in reply to Rob, 06-12-2004 13:23:47
Rob..... ..while a too lean mainjet can cause boggin', Its usually a GOVERNOR problem. Flat spotted balls and grooved ball races. Eazy nuff to check. With engine running about 1/3 throttle, try to hand-jazz yer carb to governor thottle rod for MORE rpms. Does it fight you? Play around with the throttle rod so you gitta feel, it won't byte ya..... ....Dell
Dan
06-12-2004 14:13:54
Sounds like you need to adjust your main jet on your carb. Turn the larger screw on top about 1/4 turn counter clockwise (unscrewing it). This should improve your bogging you are experiencing. Keep turning it 1/4 turn until it runs good. Usually, it is set 1 1/2 turns unscrewed from seated, but sometimes you need a little more.
Good luck,
Dan
Dave TX
06-12-2004 13:45:30
Starting out in 4th gear? Could be there's your problem....
souNdguy
06-12-2004 21:19:36
 Re: Re: 8N bogging under load? in reply to Dave TX, 06-12-2004 13:45:30
Starting out in 4th gear's the only way to use 4th gear... you don't shift an N tranny on the fly like a car tranny.
Soundguy
Notcher tractor. Rob
06-12-2004 13:29:12
Tractor's fine.
