cant get my rebuilt motor started
rob
06-30-2004 09:30:54
when i tried to start the engine it just cranks and tries to start every couple revolutions. got fuel and spark. cam and crank gears were lined up. solenoid and ballast resistor are heating up. has been converted to 12 volts. points are new and set right, new plugs, right wires to the right plugs. cant find cracked wires or ground
re used my cam and crank gear (heard of wrong marks)
cant figure it out
Dell (WA)
06-30-2004 10:30:24
 Re: cant get my rebuilt motor started in reply to rob, 06-30-2004 09:30:54
Rob..... ..check yer compression. New engine should be about 120psi. Miss-timed camshaft is gonna be about 70psi.
PROVE your ignition is working. Take any old sparkie and bend its side electrode 3/16 gap. Then insert it into any sparkie wire and ground the threads to any bolt, bracket. Does yer ignition jump that 3/16 gap with BLUE-SNOTT authority?..... ...Dell
rob
06-30-2004 10:48:30
 Re: Re: cant get my rebuilt motor started in reply to Dell (WA), 06-30-2004 10:30:24
as long as the marks line up your its right isnt it? STRONG blue spark though
gotta get over to work have to deal with it in the morning
RB(VA)
06-30-2004 09:36:08
Rob,
Recheck your distributor timing,if you're too low it will act like this.
Did you set the dist. timing before you bolted on the head?
Hope this will help.
Roy
