3 point arm mount
rob
07-24-2004 22:31:49
on the axle trumpet there is a small plate which has a pin going through it. on this pin you slide on the lower portion of the 3 pt arm. this plate has a pretty good leak. problem is, when i try to loosen the nut which keeps the 3pt arm on, the whole pin rotates. is there a way to keep this pin stationary while i loosen the nut. the other side comes off real easy (pin is stationary)trying not to remove the axle trumpet.
thanks
( Pic ) Ken N Tx
07-25-2004 01:09:23
 Re: 3 point arm mount in reply to rob, 07-24-2004 22:31:49
third party image
Sorry no quick fix here!! You MUST remove the LEFT trumpet to get to the castle nut..
( Pic ) Ken N Tx
07-25-2004 01:11:44
 Re: Re: 3 point arm mount in reply to ( Pic ) Ken N Tx, 07-25-2004 01:09:23
third party image
Dell (WA)
07-25-2004 04:54:29
 Re: Re: Re: 3 point arm mount in reply to ( Pic ) Ken N Tx, 07-25-2004 01:11:44
Rob..... ...don't forget that castelated nut is torqued to 150 ft/lbs (or tighter to line-up the cotterkey). And thats the otherreason you haffta remove the rearaxle trumpet to "fixx yer leak"..... ...Dell
