Ah! late 50 Whew.
Rob
08-09-2004 13:11:47
Mines a '51. So anyway, a guy could look at 1st gear for abnormal wear to figure it out. I guess you can see that by simply removing the tranny cover plate.
One day, huh? Maybe the wear is there before that day. What kind of wear was that on the 1st gear? On the side?
Seems like your fix is something a guy might want to do before the failure occurs.
Hobo,NC
08-09-2004 16:01:13
 Re: Ah! late 50 Whew. in reply to Rob, 08-09-2004 13:11:47
After I did a search in the archives it applys to ser # 245636 & up. I would not loose any sleep over it but would check it out if'N I were to go into the trans. My first gear did have a good grove cut into the side of the teeth on the front side of the gear and was very loose on the main shaft. at the least I would have the reverse shaft cut deeper were the retainer ring fits.
Rob
08-09-2004 16:18:38
 Re: Ah! late 50 Whew. in reply to Hobo,NC, 08-09-2004 16:01:13
Uh oh. Well, good to have the heads up. No big deal lifting the cover off that tranny and taking a look-see.
I know I do not want to shell out a tranny. I don't want to buy any shafts for sure. I just hate it when that happens.
I like this tractor one reason because it's cheap to keep. If I have to spend money on them I like them less. Oh well...
