Well you're right about the threads.
Rob
08-09-2004 15:05:48
Maybe I was thinking about how it was rusted up the other end too. Now you mention it I remember that rod and the little yoke in the lift. Little moisture gets in the lift back there. There's a felt seal in there. I oiled that up and hope it does a better job stopping moisture.
That BreakFree comes with a skinny little straw and you should be able to get it in there. Helps some that the spring is loose, maybe. You might end up getting more on the tractor than in the threads but that's the breaks. (No pun intended)
I ended up with mine turning free. Didn't take that much. I guess I started a couple days and sprayed it a couple times before I got to it. You aren't in a big hurry anyway are you?
