You bet...
Rob
08-10-2004 03:35:51
Don't lay that wheel down. You can't get the wheel under there unless the lugs are a little high. Get a pry bar or tire iron and with one hand you can lift the wheel to match the lugs. (The other hand is holding that bad boy.) You get tricky with the bar you can turn the wheel just some to match the lugs. Patience and you won't hurt yourself or break a sweat.
