Ditch needs work.
Rob
08-13-2004 14:32:34
Our county maintains the ditches. A guy can mow most any ditch, not the 150 back-and-forths but parallel to the ditch. You might be able to get the county to put a reasonable grade in there so you can mow. The county mows the road side a few times a year but lots of people keep it maintained more often.
If public works wouldn't go along I'd be visiting with my county commissioner. Course, if you've been on the commissioner about keepeing taxes low you will get that bounced right back at you and how there just aren't the resources to maintain bar ditches properly. And a nasty gouge is not a properly maintained bar ditch, for sure. Most likely, at one time it was properly graded by equipment not too unlike your N. Just look around at new road construction or rebuilds of old roads. They don't 'dig' a ditch, they grade a ditch.
