You did adjust the brakes
Rob
08-21-2004 10:39:47
out to where the wheel would not turn and then back off, right?
sm
08-22-2004 14:33:45
 Re: You did adjust the brakes in reply to Rob, 08-21-2004 10:39:47
thanks Rob. Couldnt log on last night to read your reply. Anyway, what i was saying was that i adjusted the brake thing to minimum height and the wheel is tough to turn, but I can't back off on the adjuster because it is at min (that is screwed all the way down). So I guess I will try to drive it around a bit and see what happens...
Rob
08-22-2004 14:52:51
 Re: You did adjust the brakes in reply to sm, 08-22-2004 14:33:45
I'm still guessing you did adjust the brake on hard and then back it off, it needs to be done just that way.
Good luck.
