If originality, "bragging rights" (It STARTED!), or the misery and mystique that go along with breaker points and DC generators are important to you, keep the points! If reliability, and the need to have it start when you need it, EVERY TIME are important with no ignition maintenance except for a VERY RARE change of spark plugs , go to 12 Volts and go electronic. I have done a lot of electronic conversions for myself and others (you otta see the spark my Deere "D" with GM HEI has!), and about the only concern is that many of the systems do not shut the primary current off when the engine "dies" and the key is left on. This causes the module and coil to heat up, and occasionally "die", and, of course, runs the battery down. The Pertronix II system, available for a LOT of older stuff shuts down under those circumstances. I don't know if the new system being offered for the front mount "N's" shuts down, or not, but it would be a nice feature if it did! All that being said, you sure have had an unusually tough time with your point system! I've still got a few pieces of old iron around with points, and MOST of the time they run! Have you tried premium quality points? They're a little tougher to find than they used to be, but still available.
