Piston Pin Clips
B. Jones
08-24-2004 12:21:01
My step father has a 1950 8-n that he had rebuilt about 3 years ago. New pistons, sleeves, etc. About a week ago it all of a sudden developed a bad knock and he shut it down quick. When they took the pan off they found 3 lock tabs laying in the pan and one of the rod nuts had backed off about a quarter of an inch. He said his mechanic has found no damage to the bearing or shaft other than the loose bolt. I told him to go back with Red loctite and new lock tabs. Here is my question. They also found 2 circular spring clips in perfect condition in the pan. From his discription they sound like piston pin clips. ( Tractor is 90 miles from me) I think they might have fallen in the pan when it was overhauled 3 years ago??? If they came out of the piston wouldn't they have gotten torn up getting to the pan?? Did they come from something other than the piston that uses a clip like that?? With help from this board my 2-N (6 volt) sure starts and runs great. Barrett Jones
Hobo, NC
08-24-2004 18:19:24
 Re: Piston Pin Clips in reply to B. Jones, 08-24-2004 12:21:01
Iff"n ya just retighen the rod bolts you will never be able to run it and fell safe. remove them pistons and check. i have seen what a piston pin can do and you may be look"N fer a block iff"n ya keep on running it and a pin lock has come out. Its hard to say a lock would not have damage if it came out. One thing is for sure, you would find it in the pan.
old55olds
08-24-2004 12:40:39
Nope .. They came from the wrist pins. The sleeves probably have a big groove in them. But then it should use oil.??? If they are in Perfect condition I wonder. Could someone have left them off... If it were mine I would be checking more.
Ken
