If it ain't broke don't fix it.
Rob
08-28-2004 09:35:12
jdchet
08-29-2004 18:37:41
 Re: If it ain't broke don't fix it. in reply to Rob, 08-28-2004 09:35:12
Jeez..... .if I could remember all the the things that weren't broke that I tried to fix..... ...well..... .
Jon! Don't try to over think your N! Simple machines call for simple solutions! If'N it's running good and has good power..... ..simple maintainence is all that is needed! That's what they were designed for! Keep loving your N!
JD
Steve (Magnolia, TX)
08-28-2004 13:41:30
Ditto.
I keep a bottle of MMO around, but if you don"t have any symptoms calling for using it (and from your description, you don"t), then don"t (use it, that is).
Steve
Rob
08-28-2004 13:52:42
 Re: If it ain't broke don't fix it. in reply to Steve (Magnolia, TX), 08-28-2004 13:41:30
I have a $7 quart bottle of Marvel less like 2 tablespoons or some. My 8N was puffing a bit of light colored smoke when it started and when I let out the clutch under load. I mixed some Marvel with the gas. But shortly after and before I burned that gas I turned the main jet in something under 1/8-turn and presto, the smoke was no more.
