Talc in the starter for a clutch fix?
BERT
03-03-2001 13:50:22
While searching I saw where Zane recommended putting talcum powder in through the starter housing to deglaze the clutch ?
How much do you use?
How do you know you're getting it to the right place?
Where does the talc go and can it hurt anything ?
Is baby powder ok or should you use industrial talc of a certain grit ?
ZANE
03-03-2001 14:55:59
 Re: Talc in the starter for a clutch fix? in reply to BERT, 03-03-2001 13:50:22
The talc fix is for absorbing oil on the clutch. I don't know what a glazed clutch is. If it is slipping and is adjusted right with some free play in the pedal I would say it needs a clutch disc.
Talc is a mineral that has been ground into a powder. Don't use baby powder that is starch based. Use baby powder that is talc based.
Use a whole box in the clutch housing if you can get it in there for oil on the clutch.
