Order Ford 8N Parts Online
Getting backfire but can't get it to run (8N)
Bruce Hewitt
09-12-2004 10:31:19
I have replaced everything and have the points set at .19 (?) I've been told that the front mount dist. can only be put on one way. if this is correct than I'm stuck and don't know what to do. Ant help?
( Pic ) Ken N Tx
09-13-2004 14:15:37
 Re: Getting backfire but can't get it to run (8N) in reply to Bruce Hewitt, 09-12-2004 10:31:19
third party image
third party image
third party image
Bassman
09-14-2004 05:47:58
 Re: Getting backfire but can't get it to run (8N) in reply to ( Pic ) Ken N Tx, 09-13-2004 14:15:37
I saw Kens diagram for setting points on an 8n
should the points be just opening with the tang one quarter inch of the hole line,or fully opened?.I have replaced parts in the distributor
and want to set the timing on the work bench.
Thanks JIm
Dell (WA)
09-14-2004 06:36:36
 Re: Getting backfire but can't get it to run (8N) in reply to Bassman, 09-14-2004 05:47:58
Bassman..... ...always set your frontmount ignition points gap 0.015 FULLY OPEN with CLEAN feeler gauge. Any oil (including finger oil) will cause the points to burn. Theres been reports of "lopp-sided" distributor cams bumps, so its smart to check the clearance on all 4-lobes..... ....Dell
Dell (WA)
09-12-2004 22:41:19
Bruce..... ....pointgap of 0.019 will give you weak sparkies and make hard to run. NOTE: point gap will effect your timing. Frontmount ignition timing is best set looking at a picture..... ..Dell
Rob
09-12-2004 11:26:40
 15 on the points. That might fix it. in reply to Bruce Hewitt, 09-12-2004 10:31:19
Firing order is 1 2 4 3.
Dan
09-12-2004 12:06:16
 Re: 15 on the points. That might fix it. in reply to Rob, 09-12-2004 11:26:40
That is 1,2,4,3 in a COUNTER CLOCKWISE rotation (please don't ask how I now know this so well...)
Also - the points gap should be .015 on a front mount distributor.
Good luck,
Dan
Rob
09-12-2004 12:17:17
 Re: 15 on the points. That might fix it. in reply to Dan, 09-12-2004 12:06:16
Hey Dan, you're right about CCW! Maybe it should be writen 3 4 2 1.
I think I just look at the cap, get a handle on 1 and 2 and go from there. They're marked and if the 4 on 3 & 3 on 4 is confusing don't even look, just hook 1 on 1, 2 on 2, and hook 4 on the next one, and 3 on the last one.
Not that I've ever gotten bull-headed and insisted on doing something bass-ackwards just because I wanted it to be THAT way nevermind if it was ever going to work THAT way.
