See there's the rub...
Rob
09-15-2004 17:25:53
Don't know the history of a lot of these engines; don't know how long or how well it's run with the bearings in there. You can't even figure the last guy replaced everything. I know I've repaired engines without rebuilding them, depends on the problem and the budget.
I have a 2N out there that has always (5-yrs I've known it) had low pressure but the rope seals aren't leaking at all. Makes me think something wasn't done right the last rebuild because I expect to see the seals leaking on a worn engine.
I might end up getting parts miked but I figure plasti-gage will tell the tale. I should know this weekend or next week.
ChrisH
09-15-2004 19:01:11
 Re: See there's the rub... in reply to Rob, 09-15-2004 17:25:53
Hi fellers. In my old 2n, the camshaft was the loose fitter. Even with new bearings and rebushed oil pump, the camshaft is what it is--no bearings--just the shaft running in the bored block. Anyone know how to "tighten up" the clearance? Knurlizing, maybe? Anyway, I think that's the reason for a lot of low pressure claims. Chris h (IA)
Rob
09-15-2004 19:58:45
 I think you're right. in reply to ChrisH, 09-15-2004 19:01:11
I've seen some discussion about that camshaft, oil pressure, and retro-fitting bearings. I don't know anything about knurling. Sounds like a way to go though; a lot cheaper than retro-fitting bearings.
