I'm with Zane.
Rob
09-16-2004 05:33:19
Those oil bath filters are great and they will keep you running when the conditions are extreme where a paper filter won't. Oil bath are cheap to keep too.
I don't what is in your filter. If I have it right your crud is between the air intake and the oil bath. It must not be oil. Has to be something sticky, maybe it's pollen. Try hot soapy water. It might wash right out. Soap and water doesn't work try a solvent. You probably have some paint thinner, try that.
It might have taken 50-years to get that way but I figure you'll give it better maintenance from here on out.
