Order Ford 9N Parts Online
9n Shifting Tranny Noise ?
Drmeatman
09-17-2004 07:50:43
This tractor is a project tractor (mine)for use in tractor club that I belong to.Seemed to be OK before I split it for overhaul.Didn't do anything to the transmisson but let it sit for a long time before reassembly,(health problems).Now it grinds going in gears and fairly loud whine noise moving.Have I missed something? I did replace the release bearing and pilote bearing. Thanks fellas for any help!!!
Rob
09-17-2004 08:19:53
 Grinding going into gears? in reply to Drmeatman, 09-17-2004 07:50:43
Sounds like the clutch isn't releasing. Bearing whine or gear whine. Probably bearing.
I'm working on a clutch this morning. New clutch, printing still on the face, but it does not release and all the clevis adjustment was used up. Guess what! The fingers (levers) were all set to different heights. Or more likely, the fingers were not adjusted at all. Seems the clutch must release at an angle so that would explain why it never fully releases. That would explain this problem. Did you adjust your fingers? To what, may I ask? I believe it's two-inches off the flywheel. I can't find anything on it in the FO-4. If you didn't do anything with the finger adjustment then you gotta wonder if that has something to do with your problem.
I was posting to an automechanic about this clutch and fingers and he was not happy at all with the set-up; or lack of set-up. Said stuff like "I generally am impressed by the way this tractor is designed and built but this CLUTCH IS CRAP."
Drmeatman
09-17-2004 13:18:53
 Re: Grinding going into gears? in reply to Rob, 09-17-2004 08:19:53
Rob,I used the same clutch assembly and I had punch marked as an assembly so as to reassemble as it was origanally.No I didn't do any adjustments of clutch after assembly.Had no pre knowledge one had to.Didn't read that part in the fo-4 book.Well I believe more coaching is needed here.Splitting this machine will have to wait again.Baaaaad shoulders ! Thanks a bunch. "C"
