Wagner Ford 2 FEL
BKahler
09-24-2004 12:00:14
Just recently picked up a Wagner "Ford 2" front end loader. Needless to say I have several questions before I even start to try and mount the thing on the tractor.
First, the shaft for the pump that came with the unit has splines on it but the hub that was supplied has internal threads. I do know the previous owner never had this FEL installed on his 8N. It was supplied with a crank pulley, hub for the pulley, shaft and pump assembly. Are there sources for these parts or will I have to have a different shaft made?
Second, would any one have any photos of a Wagner FEL "ford 2" showing the front mounting and rear mounting? As the saying goes, pictures can say a thousand words.
Third, what type of hydraulic fluid is used in these FELs?
I'm sure there will be more questions to follow.
Thanks!
Brad
Hobo, NC
09-24-2004 13:12:50
 Re: Wagner Ford 2 FEL in reply to BKahler, 09-24-2004 12:00:14
I got picturs and know what parts you need, email me
