Order Ford 8N Parts Online
8n tractor jack
ericlb
09-26-2004 08:21:40
ok guys, a friend of mine who grew up on a 8n in the cotton fields just told me they had a trator jack, which attached to the 3 point and would then lift the entire tractor off the ground, all 4 wheels, to change the wheel widths , now as tractors dont have a power down, how did they do this, anybody ever see one or have a pic of one, just looking at my jubilee, i cant figure out how this thing worked, thanks ericlb
valhallareject
09-26-2004 19:35:14
 Re: 8n tractor jack in reply to ericlb, 09-26-2004 08:21:40
A few things to mention..... .
1. Only use on a substantial (concrete) floor!
2. If you have "leaky" hydraulics you will need to "block up" the cross member between the lift arms to prevent lowering of the tractor.
3. It is not necessary to always use the front lift loop. If you are only needing to lift the rear wheels the loop is not used.
4. In "lifting" the tractor, it is actually rocked forward several inches up onto the front loop and rear axle stand.....don't panic!!! It will stop!!
5. Beware of the reduced (highly narrowed) center of gravity...for what goes up is just as likely to want to come back down!
PloughNman
09-26-2004 15:09:24
third party image
Hey Eric-
Here is the real deal in actual use. I use it all the time to switch my tires.
Tim
ericlb
09-26-2004 09:45:34
thats pretty cool, sure would save a lot of time working on wheels ect, i'll have to keep my eye out for 1 of those! i appreciate the info, i had no idea that those existed, thanks, ericlb
( Pic ) Ken N Tx
09-26-2004 09:19:21
 Archives in reply to ericlb, 09-26-2004 08:21:40
third party image
Found this is the Archives..
( Pic ) Ken N Tx
09-26-2004 09:09:46
 Hard to see in reply to ericlb, 09-26-2004 08:21:40
third party image
Here is a Skip"s tractor on the jack..
Ken N Tx
09-26-2004 09:11:45
 Front Jack in reply to ( Pic ) Ken N Tx, 09-26-2004 09:09:46
third party image
Jim Hickey
09-28-2004 08:13:19
 Re: Front Jack in reply to Ken N Tx, 09-26-2004 09:11:45
Ken, do you have a picture and measurments of the rear section of the jack? If you do would you please post them. Thanks, Jim
cargocult
09-26-2004 08:31:44
I have one! Did a website on it, on GeoCities. Check it out, if you want! If it is still there! Measured the thing 7 ways from Sunday, so somebody could build one if they have the proper materials. It really works, seems to defy the laws of physics, but levitates the N right up there. Very useful thing for changing tyres, etc. Enjoy!!
