If you're using that 134D universal fluid
Rob
09-26-2004 11:25:02
you might replace it with the heavier M-4864A & B, SAE 90 above 32-degrees, SAE 80 below 32-degrees (if slow is a problem). The heavier fluid won't get by the worn rings/cylinder so fast.
Thanks for the tip.
