I got a new cable, tossed the new
Rob
09-29-2004 09:13:59
jacket and used the new guts with the old jacket.
Take the cable out of the jacket and stick the end into the governor to see if it fits or something is worn. You can check the other end also.
Now when you go to install the cable jacket and all, you need to make sure the cable is seated, both ends. You can't just poke the connector on there and screw it up. Make sure it all goes in right. I guess you fit the governor end first, you can screw it on and then try turning the meter end to see that it went right. Then you can fiddle with the meter end to get it fitted right.
Good luck.
