Voltage at the top of the coil should be min 2.5 max 3.5 with 3 being pretty good... these are 'points closed'. Points open would be battery volts. You might have poor wireing, and bad electrical connections, including your key switch. Resistors usually fail 'open'.. not short.. so your resistor is most likely ok. .though the contacts for wire hookup could be dirty/coroded. Do a quick test. run a good 14awg or better jumper wire from the battery to your disconnected and cleaned resistor, to your key switch, and to the coil. measure voltages.. now bypass the key switch by twisting the newends of your jumper wires over. Take another reading. This should help you isolate the bad conenctions/wires. The ballast resistor is still available at many online parts houses.. like here.. and at the nh dealership probably ( possibly? ). Make a diagram before you start disconencting wires. If it is a wireing problem.. TSC sells a good el-cheapo wire harness. Soundguy
