Rob..... ...I'm certain that what you wrote makes sense to you, but it leaves my head spinning. I'm gonnna assume you know the difference between an alternator and a generator. And when you say "alternator" that implies a 12 volt conversion, you really should explicitly state type of battery system. You should really state which model of N-Tractor you are talking about because the OEM electrical system is different and must be modified differently. And in addition, sometimes it really helps to know WHY you ask your question. You wrote: (I'm gonnna add some line numbers so we both know what we're talking about) 1) Regulator to Alternator (F Connections) 2) Regulator to Coil 3) Regulator to Solenoid 4) Alternator to ammeter 5) Alternator to regulator (F Connections) 6) Alternator to base of regulator for ground 7) Ammeter (+) to Alternator 8) Ammeter (+) to ignition switch 9) Ammeter (-) to Solenoid 10) Coil to resistor (not sure it works) to Solenoid 11) Coil to distributor x 2 Now specifically to answer your wiring questions: Sounds like wire #1 is the same as #5, is it? Sounds like wire #4 is the same as #7, is it? Sounds like wire #2 & 3 are the same as #10, is it? Iff'n this is a typical 12 volt conversion, and the popular Delco 10SI was used, it ALREADY has a built-in voltage regulator, and so the uses of OEM squarecan voltage regulator is somewhat dis-ingenuous except to use as a wiring tiepoint. Howsomevers, iff'n instead, this is a NON-STANDARD alternator that requires an EXTERNAL voltage regulator, all betts are OFF!!! I know 8-ways to convert to 12 volts and they all work, some are more elegant than others. But your 12 volt conversion (iff'n thats what it is) doesn't match my knowledge base. You also wrote..... "Will leaving your key on without the engine running burn out the points and the coil?..... YES, if the points are closed..... . "If not, is my system wired wrong?"..... .it mustta been wired correctly, 'cuz its been running. Iff'n its stopped, must be for a reason. And until you understand the simple principles behind how a 12 volt conversion works, don't un-wire 'nuttin'..... ...respectfully, Dell a 12 volt advocate for the right reason.
