I'm confused
Rob in VA
09-30-2004 10:29:25
HTR,
Before I start, I am not getting any charge out of the alternator so I think something is wired wrong. According to a generic wiring diagram I have, the Reg is wired as follows
F: goes to F on the alternator
2: goes to the coil
3: goes to the solenoid
4: is not used
R on the alternator is not used.
Ground from alternator is wired to base of regulator which is bolted to frame.
So with that being said, which wiring schematic do I use.....I have been doing a lot of research on this via the net and have yet to come accross a common way to wire this thing.
thanks
Rob
09-30-2004 12:06:55
 Take another look at the drawing. in reply to Rob in VA, 09-30-2004 10:29:25
You have the regulator wired to the coil. The regulator and the alternator are (in) the charging circuit while the coil is in the ignition circuit. They coil has no business being connected to the regulator.
The coil is connected to the resister or what is the point of a resister.
