Had a time finding a floor board to remove.
Rob
09-30-2004 15:06:52
Once I got that taken care of I looked like Donb told me and as soon as I pulled off the throw-out bearing I knew right away there was a situation.
The shifter fork was held on with a double-nutted 5/16" bolt and not the 5/16" flat head pin as advertised. So I grabbed the shaft and the fork and twisted and sure 'nough, they moved in two different directions all at the same time. Got the bolt off and the fork moved to the side and can see the hole through the shaft is wallowed out. There is 1/2" slop in the travel of the throw-out bearing. The bolt was bent, too.
Shouldn't be any big deal to bush it.
Hobo,NC
09-30-2004 15:44:54
 Re: Had a time finding a floor board to remove. in reply to Rob, 09-30-2004 15:06:52
Yep I bet ya did. was thinking if ya got it back together and still had yer problem to make sure ya had no interference with the pedal. Sounds like ya got it.
