I don't know if it took a leadfoot.
Rob
09-30-2004 16:33:33
On that 2N the clutch pedal also operates the brake.
I learned a few things about the clutch while I was about it. I learned a close inspection of the shifter fork, the shaft, and the shaft bushings must be part of replacing a clutch. I imagine the right-side shaft bushing will need replaced with the clutch. This one sure needs a bushing. $5 split bushing...cheap. You want the far end of the shaft held tight or everything gets turned cocked when you push on the pedal. That and a leadfoot and you're doomed to ruin the $15 shaft, the $15 throw-out bearing plus the $2 pin.
Not to mention replacing the clutch doesn't fix nothing. I bet that's how this new clutch ended up in here. The old clutch wasn't bad but he missed this shaft problem. Must have bummed him to change that clutch and end up with no adjustment.
don b
10-01-2004 08:56:37
 Re: I don't know if it took a leadfoot. in reply to Rob, 09-30-2004 16:33:33
Rob, glad you found the problem.You are correct about checking the other parts as well.I don't like halving a tractor two or three times either.It's amazing what and how fast we learn while working on these tractors.Just been there and done that like you and many others have done. don
