Metal in the oil pan
Mark M
10-03-2004 20:15:59
I have been working on a 1940 9n for a friend of mine. I did a oil change on it yesterday and found a problem. When I drained the oil I found a broken cotter pin ( about 1 inch long ) and alot of metal chunks. There is about 5 or 6 pieces a inch square and a handfull of others from a 1/4 to fine grains. The tractor runs great but the oil pressure is a little low about 15 to 20 psi. I think its the oil pump. I would like to be sure before,I give him the bad news. Any ideas?
raytasch
10-04-2004 10:41:17
 Re: Metal in the oil pan in reply to Mark M, 10-03-2004 20:15:59
What kind of metal? Aluminum, as in a piston skirt? ray
souNdguy
10-04-2004 07:36:33
I agree with the others. Also.. 15-20 psi isn't really considerd low... 0-4 psi is low... 6psi+ hot idle is a working tractor. If you can keep double digits at hot idle you'r doing great.
Soundguy
Rob
10-04-2004 03:05:32
 An inch square? in reply to Mark M, 10-03-2004 20:15:59
Exactly how thick are they? Metal has 3 dimensions and all are important to id the metal.
Don't know of any cotter keys used in there. Spose to be wire but some bozo might have used keys on the mains. If a guy used keys on the mains no telling what else he rigged.
Russ in SoCal
10-03-2004 21:16:57
Mark,
With that much metal and still holding fair oil pressure, I think you may have the remnants of a sleeve that tried to escape out the bottom of a cylinder. Someone could have replaced the sleeve from the top and never checked further. The cotter pin may take a little detective work. Probably want to drop the oil pan. Hold up the tranny and swing the front end out of the way. Sounds harder than it is unless you have an FEL. Let us know what you find.
Russ
