How you know it's oil/gas?
Rob
10-05-2004 07:40:44
Is it milky? That's water/oil. Really good trick getting gas in there. Talk to the guy that fills the gas tank.
Anyway, clean out the filter and fill with engine oil to the fill line.
You can tug-tug to remove the element (needle-nose easy does it) to clean. If it's been forever you might have to pull the cleaner off and slosh some solvent (paint thinner is fine) around in there to dissolve the crud to free up the element.
I put cork gaskets on it.
