It just lays against the lift arm.
Rob
10-06-2004 04:10:45
It keeps the drawbar from rolling backward. That long skinny bolt just lines things up. If that was a j-bolt it could hook over the top of the lift arm. I ended up nutting a piece of slotted angle-iron to the end of the long bolt to keep the drawbar from rolling forward. The angle-iron is only a couple inches long and is loose on the bolt. I just flip it over the lift arm. The bar would roll forward when there was no trailor on the ball.
Fact is, when the ball is clamped in the receiver it only rolls so far. I suppose years of banging on the receiver would cause a problem if you don't lock the drawbar.
