There's a trick to brg inserts.
Rob
10-08-2004 03:31:34
They have a cam lock scheme. Insert the shaft through the collar and then the bearing and then the other collar. Hold the bearing race and rotate the collar to lock it against the cam shaped bearing race. Get it tight and drive the set screw locking the collar on the shaft. Repeat for the other collar making sure both bearing cams are locked and the collars are set tight on the shaft.
Lots of guys fail to properly lock the collars on the bearing race and things start slipping down the road.
