Good spark and plenty of gas...
Rob
10-10-2004 02:56:57
Subjective stuff there. A 'good spark' is a snappy, blue spark across the spark plug. A yellow spark is not a 'good spark' and if that's all you got you're running on luck and it will fail at crunch time.
'Good flow' to the carb is a 'full-pipe' flow out the fuel line. A pretty good flow out the fuel line is not good enough. 'Full-pipe' flow. You got that then remove the brass elbow and clean the screen.
You got that and it ran before it will run again. Starter fluid is a good way to get a handle on the problem.
