Coil may have been knocked loose.
Rob
10-12-2004 06:04:49
If the bail isn't seated properly the coil will move in a head-on with a tree. Bail gets screwed up when a guy pulls out one end to remove the coil. It's probably impossible to get the end of the bail seated properly while the bail is over the top of the coil. The bail might even be bent around and misshapen.
Inspect the wiring front-to-back to see if something was snapped or dislodged.
