o/t kohler 16hp
lakeport rob
10-13-2004 10:03:06
i have a old ariens s16h when you go to start it cold it will start with the choke and die as soon as you push the choke back in. i know it sounds like a dirty carb but its not. the plug gets fouled out and when you put in a new one it does the same thing. does anyone know how far out the idle and main screws are supposed to be turned out? also ( this is wierd) when i take the plug out and leave it attatched to the plug wire to check for spark, i get shocked as soon as the key is turned to acc. also get shock when you turn it back off. is this indicative of a bad ignition switch? could this be why it wont run? thanks
(URL) Ken N Tx
10-13-2004 12:35:41
 Small Engine Board in reply to lakeport rob, 10-13-2004 10:03:06
Check out this Board for help..
