Gas measuring stick for a NAA
Neal
10-22-2004 19:31:40
Does anyone have the gallon measurements for the gas tank on an NAA? I have made one up for my 2N from info provided for a paint stick for the older Ns. Because of the different tank configurations, I would doubt that they are the same for the older Ns and the NAA.
Jim.UT
10-23-2004 07:31:20
 Re: Gas measuring stick for a NAA in reply to Neal, 10-22-2004 19:31:40
You could do it yourself but it would be kind of a pain. I did it on my 850. The measurements would not apply to your NAA because the tank capacities are different. NAA = 11 gal (I think) and 850 = 14 gal.
Here's what I did. I waited until the tank was mostly empty, then I disconnected the fuel line and drained the rest of the tank into my empty gas jugs. I made sure I had enough gas on hand to refill the tank to the top then I added gas a gallon at a time, putting a stick in after each gallon and marking the fuel level.
I don't have that stick anymore. I don't remember what happened to it. I probably stepped on it and broke it. Now I just use a wooden ruler cut off to 10" so it will fit in my toolbox. When the tank is full, it comes up to about the 9.5" mark so I just judge from there. I don't had fuel stabilizer because I use the tractor all year.
Russ in SoCal
10-23-2004 14:09:29
 Re: Gas measuring stick for a NAA in reply to Jim.UT, 10-23-2004 07:31:20
I did that too. But the second gallon dissolved the crayon mark from the first!
Russ
P.S.Have you looked in the gas tank for your stick? ; ^ )
Jim.UT
10-23-2004 16:13:50
 Re: Gas measuring stick for a NAA in reply to Russ in SoCal, 10-23-2004 14:09:29
I haven't dropped the stick in there, yet, but it could happen. I have to grip it firmly with thumb and index finger to stick it down in there. I would have preferred to leave the extra 2" on the ruler, but the 800 toolbox is only about 10.5" long.
Next time, notch it with your pocketknife instead of using crayon!
Russ in SoCal
10-23-2004 16:20:39
 Re: Gas measuring stick for a NAA in reply to Jim.UT, 10-23-2004 16:13:50
Ya need a chunk of one of them folding carpenter"s rulers. I wonder if my Dad still has any of the three or four I broke as a kid????
DJ in Pa.
10-23-2004 05:22:51
 double sheesh in reply to Neal, 10-22-2004 19:31:40
Don't feel you need to explain yourself, it is a good question. D*** needs to lighten up.
Dell (WA)
10-22-2004 21:03:19
Neil..... ...does it really matter to know by your dip-stick that you have exactly 3.35 gallons of gas in the tank? It would seem to me that just knowing that your have about 3 gallons left and ya better top-up the 10 gal tank, is all you really need to know. And I can judge that I need to top-up without even knowing that I have exactly 3.35 gals of gas in the tank. Sheesh..... ..... Dell (sorry)
Neal
10-23-2004 01:31:12
 Re: Gas measuring stick for a NAA in reply to Dell (WA), 10-22-2004 21:03:19
Dell:
It does matter if I want to add Stabil to the gas for the winter months when the tractor sees less use. Adding too much stabil is just as bad as not adding any. I live in the metropolitan Milwaukee area and we are mandated to use the "funny gas" here. I buy "regular" non reformulated gas in the next county for use in my tractors and other small engines. I have been told by a number of mechanics in the small engine business that my motors will last longer and give better performance if I stay away from the reformulated gas in these engines, and especially in the 2 cycle engines. I am not worried about running out of gas, as I live in the country and do keep extra non-reformulated gas on hand, as I have a lot of engines that are on off road vehicles.
I also believe in using Stabil, as it's use to me is a lot better than having to remove and clean up varnished carbs because they need to sit for rather long periods of no use.
Dell (WA)
10-23-2004 08:58:25
 Re: Gas measuring stick for a NAA in reply to Neal, 10-23-2004 01:31:12
Neal..... ....since I buy and fill my N-Gas with 5-gal gascans, I just add "Stabil" to the 5-gal of gas as I buy it. It is always mixed properly for enny gas engine usage. But iff'n its that important to you, then make your own calibrated dip-stick. You should be intelligent enuff to handle that simple task. ..... .Sheesh..... .. Dell (sorry, again)
Neal
10-23-2004 09:39:48
 Re: Gas measuring stick for a NAA in reply to Dell (WA), 10-23-2004 08:58:25
Dell:
No need to be sorry again. I was either a general foreman or a department head for 35 years before retirement and worked with many engineers in a manufacturing setting. Some were very bright, brilliant I might even say. However, some of them lacked two things that I possesed, experience and common sense. I may be wrong, but I thought this forum was to allow the uneducated to gain info from those that already "invented the wheel". Since I already know my tank holds around 10 gallons, I could drain it and add a gallon at time and measure and record the same. However, if someone on this board has already done this and is willing to pass on the info, It would save a lot of time.
Sometimes if one has no constructive info to pass on when a question is raised, it is better to say nothing.
( Pic ) Ken N Tx
10-23-2004 01:01:32
 9N/2N/8N Gas Gauge in reply to Dell (WA), 10-22-2004 21:03:19
third party image
Here is the gas guage for those who donot have it..
jdchet
10-24-2004 18:58:43
 Re: 9N/2N/8N Gas Gauge in reply to ( Pic ) Ken N Tx, 10-23-2004 01:01:32
third party image
Gas gauge for an N? Kinda takes the adventure of leaving the house on the old beast! Next thing we're gonna want is heat and a/c!
JD :-)
Neal
10-23-2004 01:41:18
Ken:
Thanks for the info on the measurements for the Ns. I have made up "sticks" for the Ns, but I also need the measurements for the NAA tank, as it is has a completely different configuration than the regular Ns tanks. I know when I run out of gas, as the motor will quit. (grin) What I am trying to avoid is running out of gas when plowing during a snowstorm or when bush hogging in the summer months. My tanks are extremely clean and looking in them does not give me a close estimate of how much fuel is in them.
( Link/Pic) Ken N Tx
10-23-2004 04:36:52
 Re: 9N/2N/8N Gas Gauge in reply to Neal, 10-23-2004 01:41:18
third party image
Ramrod
10-23-2004 05:31:13
 Re: 9N/2N/8N Gas Gauge in reply to ( Link/Pic) Ken N Tx, 10-23-2004 04:36:52
The boys at Red Rock are working on a gas cap/gauge for the NAA. I hopt to be testing it soon. The main concern is the clearance for the hood door to close properly.
A NAA stick would be nice in the meantime.
Where in NTX are ya Ken?
Ramrod in Wise County
K Pike
12-31-2004 22:03:13
 Re: 9N/2N/8N Gas Gauge in reply to Ramrod, 10-23-2004 05:31:13
I'm afraid you'll just have to wait until somebody else makes it first cause he has no original ideas and can only steal other peoples work. Just look at his page you, see anything original? Nothing, all made by somebody else just like "his" gas gauge. what a sorry loser. Taking credit for things he didn't do. Want proof just ask i'll show you.
Ken N Tx
10-24-2004 02:51:24
Denton County/Wise County border..(Krum)
Ramrod
10-24-2004 05:59:28
 Re: 9N/2N/8N Gas Gauge in reply to Ken N Tx, 10-24-2004 02:51:24
Howdy Neighbor!
Ramrod in Rhome
