Thanks
Rob G (KS)
11-21-2004 06:44:34
I will get it done and let you know how it goes. Thanks for the PM ideas.
Craig R.
11-25-2004 07:00:42
 Re: Rusted Clutch in reply to Rob G (KS), 11-21-2004 06:44:34
I just split my 8-N after trying every possible way to jar my frozen clutch loose. I also learned why my solenoid would just click in the cold of our NEng. winter. A mouse must have got in through the timing hole and built a nest. It blocked the drainage holes. I had 3-4" of water in there which would freeze up the flywheel. I used a torch on the rusted screw holding the timing hole cover so it stays where it should to prevent future mouse nest problems.
