Gaskets and oil
Rob N VA
11-26-2004 19:22:24
I know that you are supposed to "dab your finger in the oil and spread it around the new gasket" when you are replacing the oil filter. I know this the way most of you know this; because that's what our fathers told us to do. My question is why??? It just struck me today while watching one of those "old car fix-em-up" shows, when I saw the mechanic do that very thing, but he failed to tell the audience WHY he did it. I knew that the collective intelligence of this forum would be able to give me a scientific reason, that will probably make me feel silly for not seeing through the cloud straight through to the simplicity. Thanks in advance for your time!----Rob
Geo in SD
11-27-2004 21:00:59
 Re: Gaskets and oil in reply to Rob N VA, 11-26-2004 19:22:24
The side of the gasket that is oiled usually won't stick to it's sealing surface, making it easier to remove the part in the future.
old
11-26-2004 19:40:02
Well if you don't you will rip the gasket/seal off the bottom of the filter and then you have a very bad leak. It also make it easyer to remove the filter when you are replace it. Had one once that a guy didn;t oil the seal and we had to remove it in pieces, cut it off till we got to where the seal was and then we could get the rest off.
Marty 2N IL
11-26-2004 19:33:06
I was always told that because when you spin it on you don't want it to buckle up and leak It has to slide until it commpress. We do o rings at work with grease for the same reason.
Marty
