Tire pump
Rob 9N
12-29-2004 12:50:38
Happy new year y'all. I have been working Frances to death with the record snowfall that we received. Just a note to newbies, be patient. these tractors are worth their weight when they are working correct. I have calcium filled tires and noticed one is starting to show on the low side. Is there an afordable hand pump that I can put new calcium in with? I have the old tires and one still has a good deal of juice left. I hate to think I would have to take the tire off and drive 10 miles one way. It's not flat, but it's definatly getting low. Thanks in advance. Rob Johnson
Tim PloughNman Daley
12-30-2004 05:02:57
 Re: Tire pump in reply to Rob 9N, 12-29-2004 12:50:38
Hey Rob-
You might want to consider draining the CaCl because that stuff is nasty and is probably eating away your rims from the inside out hence the "leaking". There is a newer, safer, substance made from beet juice called Rim Guard to use as a substitute. Google rim guard for their web site. I have no affiliation with them other than I use their product -have had it in my rears tires for five years with NO PROBLEMS. your local AG Tire dealer would carry it. HTH
Tim Daley
Dave H (NY)
12-30-2004 04:17:31
To make life easy go to Sears or Wal-Mart and buy one of those 12 volt emergency tire pumps, plug it in to 12 volts put it on the valve and pump away.
H Kutzler
12-29-2004 13:20:26
I think you just need to stop your tractor with the valve stem close to the top and fill it with air. I think it is recomended to have 14 lbs of pressure in them.
DJ In Pa.
12-29-2004 12:56:41
Has the solution leaked out? sounds like it just needs air?
Rob 9N
12-29-2004 18:12:40
 Re: Tire pump in reply to DJ In Pa., 12-29-2004 12:56:41
Wow! you learn something new every day. I asumed,(careful), that they were full of Calcium. I never had to do anything to the tires. I didn't realize that there would be air as well as calcium in the tires. I'll check and try to fill with air. Thanks, Rob Johnson
