snow blade photo
DJ in Pa.
01-26-2005 07:37:42
First time posting photo.If you use the link you can see five pictures. PS what is the difference between a link url and a photo url? I tried this same address as photo url and it did not work?
( Pic ) ken N Tx
01-26-2005 14:17:38
 Re: snow blade photo in reply to DJ in Pa., 01-26-2005 07:37:42
Here is one pic
third party image
DJ in Pa.
01-26-2005 15:52:57
 Re: snow blade photo in reply to ( Pic ) ken N Tx, 01-26-2005 14:17:38
Thanks ken. Where did you find the url?
Ken N
01-27-2005 14:33:16
 Re: snow blade photo in reply to DJ in Pa., 01-26-2005 15:52:57
Right click on the photo
( Pic ) Ken N Tx
01-26-2005 14:20:52
 Another in reply to ( Pic ) ken N Tx, 01-26-2005 14:17:38
third party image
( Pic ) Ken N Tx
01-26-2005 14:25:57
  Another in reply to ( Pic ) Ken N Tx, 01-26-2005 14:20:52
third party image
TIMW(PA)
01-26-2005 10:14:12
third party image
If you want to post a link you copy the address in your browsers address bar and paste it into the Link url box. Then give it a title that makes sense into the link title box. If you don't give it a title it wont post. now to post a pic go to your picture hosting site right click on your picture and either click "copy image location" or go to properties and high lite and copy the adress there. Make sure yoou click on the picture first to make sure it is the larger version or else you will end up displaying the smaller thumbnail. Also A title is not necessary for the pic....Tim
TIMW(PA)
01-26-2005 10:17:27
 Re: snow blade photo in reply to TIMW(PA), 01-26-2005 10:14:12
Looks like your photo hosting site is not letting the pic access. Try putting it on ytmags' galleries page...it'll display from there. just go over to the menu on the left click on tractor photoes, select your catagory and follow instructions to post your pic...Tim
JimH
01-26-2005 09:20:32
Speaking of wheel weights, how did you design and attach your wheel weights?
DJ in Pa.
01-26-2005 16:00:29
 Re: snow blade photo in reply to JimH, 01-26-2005 09:20:32
I found man-hole covers that were the right diameter, They averaged 87.5 pounds apiece.I drilled the hubs to mount the inside ones. Two 5/8" hardened bolts. Then I drilled center of inside weight and used 5/8 hardened bolt to attatch outer one.Getting them centered took a little time. I finished the surface with filler.
Sal8N
01-26-2005 08:13:43
Nice photos...looks like a good set up.
Impressive wheel weights there.
So this is your own design...nice, would like to know more about how you did it.
Sal
