Wagner FEL front mounting bracket drawings
BKahler
02-03-2005 17:08:53
Several forum members asked if I could provide them drawings of my Wagner model "Ford 2" FEL front mounting bracket. I finally finished drawing them up in Autocad. What I have done is posted a jpg of the drawing that is large enough to print. I've also provided links to the DWG and DXF files if anyone wants to tweak them using Autocad.
Follow the link below and go to the 1945 Ford 2N link in the upper left corner of my home page. From the Ford tractor page go to the bottom and you'll see the photo and the links.
Hope this helps some of you out there. If you have any questions feel free to contact me.
Brad
Tweeter
02-05-2005 19:15:42
 Re: Wagner FEL front mounting bracket drawings in reply to BKahler, 02-03-2005 17:08:53
The drawing you provided has a minor problem. The depressed "v" shape was drawn on the bottom side of the mount. It should be on the top between the two 90 degree bent ears.
BKahler
02-06-2005 19:23:08
 Re: Wagner FEL front mounting bracket drawings in reply to Tweeter, 02-05-2005 19:15:42
Oops! Sorry about that. I'll correct the drawing tomorrow and get them reposted. Thanks for catching the mistake.
Brad
Tweeter
02-03-2005 17:23:47
Thanks for posting the AutoCAD drawings.
